BIG Tyres & Wheels - questions for 5" lift.
  • BIG Tyres & Wheels - questions for 5" lift.
    im thinking of buying another surf and using it on and off the road, if i get it raised 5" (i have read the tutorial) then what tyres should i go for, im trying to get an idea what its gonna cost me to get offroading, i might get one with a lift already so it may be the wheels and tyres i need to source.
    whats the difference in cost between 31" and 33" tyres and what wheels will i need, how much does ride quality and mpg suffer if i was going to get a 3.0td.
    i take it these things are like hens teeth to get second hand?
    2nd Gen 3.0td, running on waste veg oil
    33's would fit with a 5" lift - 33's are more expensive than 31's as you should replace the rims as 33's are wider (normally) but they do look the mutts!
      With a 5" lift you'll prob get 35's on,(if you can afford em) i think rodleach only had around that amount of lift plus some bashing away at the inner rear of the front arches
      33's will fit no bother, i have 33's on 15x8 rims and they fit fine, (4" lift front)
        well money will be a big factor lol, so will depend on the difference between the sizes and effects on ride quality and mpg,
        i love the look of your truck, very nice
          You will take a hit on mpg, obviously.
            so roughly what dia in inches are the standard tyres and how much will mpg suffer?
            what will a set of 31" or 33" tyres set me back?
              My General Grabber AT2's - 33", on nee 16x8 modular wheels were just shy of £800
              www.vidamusic.co.uk
                oh jings thats way more than i was hoping for
                  £800 for new wheels and tyres is cheap!! What were you ecpecting?
                  More Lift.
                  More Tyres.
                  More Engine.
                    having never bought these before i had no idea, its a big cost on top of the price of the surf i may buy, i may be better buying the 31" tyres and sticking to the original rims.
                      Save yer money, the bigger tyres will only give a wee bit of extra clearance at the diffs.
                      You should lift as little as you can but as much as you need.
                      A rear locker and some good 31 MT tyres will get you much further.
                      Alan
                        Bigger wheels also puts a lot more strain on the trans' unless you gear down the diffs and/or the transfer case to compensate. Anything more than than the knarlier green lanes will see CV's broken.
                          +2 on that an all..
                            That's just not true.
                            I've been running 33's in the worst Clog conditions for 3 years and never broken a CV or anything else. (except a front diff, but I was towing a trailer through 3 ft of mud with a Jimny on it)
                            Alan
                              I thought 31" was pretty damn close to stock anyway on a 3rd Gen?
                              More Lift.
                              More Tyres.
                              More Engine.
