It's a bit urgent, and nobody seems to be in mechanical, so I thought I'd post in here.
I think my coolant level is low.
In the tank at the front right of the engine bay the fluid level is below the change in shape leve (if that makes sense).
I think that this means it's low.
From what I could see the change in shape is the indicator for full.
To top up this coolant can I use water?
Should I mix it with anything else?
I've read that you should not fill up via the expansion tank, maybe I'm getting myself confused, I thought that the tank I'm talking about is the expansion tank - yet this is where the full indicator is.
Hope that all makes sense, or can at least be understood.
Any info gratefully recieved before I set off in a 300 mile journey.
