I've got a coolant leak on my truck and I think it may be coming from the water pump - It's dripping from the bottom pulley on the engine. I can't see anywhere else it could be coming as i'm sure its leaking behind the cambelt cover, The pipes that cross the engine above the waterpump are fine.
Does this mean the cambelt has to come off?
The waterpump is only a couple of months old is it likely to have failed?
Is there a block plug in this area that could be leaking?
Should I start panicing?
