1990 Surf fuel pump & veg oil
  • 1990 Surf fuel pump & veg oil
    Hello all
    I have recently taken possesion of a 1990 Surf LN130, and am going to start experimenting with SVO. From everything I have read here (very very informative - thanks all posters)and on other web pages, I understand that a Bosch style fuel pump is more suitable for vegoil rather than Lucas/Cav variations. I have also read that the 2nd gen Hilux was built with a fuel pump that was based on a Bosch design, but having very little mechanical knowledge is there anyway I can check what fuel pump is in my yoke - either by looking at it or checking manufacturers details somewhere?
    And if I cant tell which pump it is and I crack on and try this..... http://www.bio-power.co.uk/tryit.htm
    and discover that it doesnt like SVO, am I going to do any irreversible damage?
    thanks all
    Hi n welcome David, 1990 Surf sounds like ya have 2.4 Lt engine with a mechanical Denso I P (mine was) as a posed to the later 2.4 Lt/e, so you'll be fine.....
    With the weather we're having it's ideal to start using SVO/WVO, start 50/50 n see how ya get on ....
    I'm not saying ya will but keep an eye out for signs of Veg oil leakage from the I P caused by rubber seals degradation ....
    Good Luck
    Jess
    nearly 10 years of Surfs
    "Cos short cuts can cost more in the long run"
    Buncefield Burner
      thanks Jess....
      As my first post I had to post this in the newusers corner and then lost were it went... thus the other post,
      http://www.hiluxsurf.co.uk/showthread.php?t=70398
      but thanks very much for replying to both.
      I'm guessing that IP is injector pump, which in my clueless mechanical world is the same as a fuel pump, which is going to suffer the same problem as Albannach mentioned in the other thread????
