For anyone who has fitted an after market rad.
I have a new rad in the 2nd gen I am selling and the cap sits in the wrong place when tight. Alans surf with after market rad is the same although in a slightly diffirent angle.
This means the lug rubs on the underside of the bonnet and slackens causing the system to lose pressure.
Easy fix remove one lug. Worth checking if you have an after market rad.
Cap does not sit with lugs linned up along the rad like the original did.
Cap rubs on the bonnet when shut, rub makks are visable.
Lug removed issue fixed
