Right guys I have a problem or at least I think I do. I noticed water under the car and i tracked it to a little pipe and im not sure if something has fallen off or if it is an overflow pipe for something. Its near the left hand front wheel.......Please help any ideas????????????/
Help Im Leaking
Do you have air con and if so have you been using it??Originally posted by McWibbleRight guys I have a problem or at least I think I do. I noticed water under the car and i tracked it to a little pipe and im not sure if something has fallen off or if it is an overflow pipe for something. Its near the left hand front wheel.......Please help any ideas????????????/
Is it just plain water or is it coloured??
There is an overflow for the Air con systemNO WORRIES!
Rusty
Are you losing any coolant?Have you got the aircon on? That leaves a puddle in the area you describe.Originally posted by McWibbleRight guys I have a problem or at least I think I do. I noticed water under the car and i tracked it to a little pipe and im not sure if something has fallen off or if it is an overflow pipe for something. Its near the left hand front wheel.......Please help any ideas????????????/
Pete
