is the rear diff ratio in a petrol hilux the same as in a 3.0td surf and if not want surf diff will be the same or can i fit the diff from a hilux into a surf axle ?
rear diff ratio
No, a petrol one, I think so (so long as it's an 8" one).Originally posted by lukenemma View Postis the rear diff ratio in a petrol hilux the same as in a 3.0td surf and if not want surf diff will be the same or can i fit the diff from a hilux into a surf axle ?Do you know that, with a 50 character limit, it's
that the propblem, the idea is to fit a rear axle off a surf to a hilux pick so that it can be coil sprung not leaf and i'm trying to work out witch axle i need for thisOriginally posted by yoshieToyota has 4 differential types in pickups and 4Runners -- the 8" standard, the 7.5", the 8" V6/Turbo, and a new one in the Tacoma and third-generation (96+) 4Runners.
The most common is the 8" standard. It is used in the rear axle on '79-95 (96?) 4WD trucks and 4Runners, and 3/4 and 1 ton 2WD pickups, and it is also used in the front axle on 79-85 (solid beam) pickups and 4Runners.
The 8" V6/Turbo axle is found in some turbo and V6 models, and is a little beefier. It is a 4-pinion design, whereas the regular 8" is a 2-pinion design. Many V6's had 2-pinion cases too.
The 7.5" differential is used in the front of IFS trucks ('86 and later). It is also used as the rear differential on some 2WD trucks.
The above might not be 100% but it has or a version of been repeated on a few sites.
If you fit the diffs as matche pairs you will have no issueshttp://www.mudmuppet.com
Originally posted by yoshieWeld spring perches on the pickup axle.
Sounds like you need to do more research, if this part stumps you, you will have no chance of working out trailing arms and the like
the work seam's easy just dont want to put the surf axle on the the ratio be wrong and he want's to use the surf axle as it's a lsd thats why i was askinghttp://www.mudmuppet.com
Try HogwartsOriginally posted by lukenemma View Postthat the propblem, the idea is to fit a rear axle off a surf to a hilux pick so that it can be coil sprung not leaf and i'm trying to work out witch axle i need for this' You've arrived on a rather special night. It's one of the master's affairs.'
Any Toyota 8" diff will fit the back axle your truck, only IFS 7.5" diffs will fit in the front.
There are different ratios in all trucks, you need to know what you have if you're going to mix and match from a pickup, or you need a IFS truck (97-01) or IFS 1st or 2nd Gen Surf to swap a pair of diffs.
Different ratios work better or worse with different tyre sizes4x4toys.co.uk - Keeping you on and off the road...
