@ Wishbone.
  • @ Wishbone.
    Hello Rob. Spotted a pic of your truck in an old post in the mods section. From what I could see, it had what looked like Mk3 Astra roof rails. If so, did you fit them? Do they have seperate baseplates to attatch the rail to? Did you use "Rivnuts"?, or bolts from the inside?......Any info would be much appreciated. Pics, especially....Cheers....Mick.
    " Time wounds all heels ".
    Hi Mick,
    The rails are from a frontera (swb I think). They have big threaded studs fitted so I just drilled the 4 holes per side and used some 3mm steel plate on the inside as big washers.
    I've still got a plywood drilling guide I laser cut at work if you end up getting the same rails.
    Cheers,
    Rob.
    Will sort some pics out at the weekend as the missus has the truck tonight.
      pics.
        Thanks Rob. I can see them more clearly now. They look great, but they are a little shorter than the ones that i need. Iv'e only seen Astra ones fitted once, and they were on a burgundy 2.4 that Stormy sold.....Does anyone on here own it now?.....Cheers.....Mick.
          Rob, are you anywhere near Harwich?
          Sent from the iPad you "lost"
            why you swimming back slobbo
              Peugeot 405 estate rails fitted to mine all those years ago!
              http://www.hiluxsurf.co.uk/attachmen...9&d=1131926529
              p.s. Thats the wrong date on the photo, as it would have been dark at that time. It was june 2004 if I remember correctly.
                Stansted, but I was up that way a few weeks back picking up a pillar drill....
                why you ask ?
                  You, yer fecker...
                  I need a favour from you, I'll come and see you at the beginning of April.
                  Still in Stratford?
                    why you ask ?
                    I'll be hanging around Essex next month.
                      You, yer fecker...
                      Still in Stratford?
                      yeah still here , you gonna spend some money this time ?
                        [QUOTE=BUSHWHACKER;706814]Peugeot 405 estate rails fitted to mine all those years ago!
                        Thanks Vince. I know that 406 rails are the popular choice, and there are some really good write ups on here, on fitting them, and call me weird, but I've set my heart on Astra ones....Cheers....Mick.
                          I want a 2.4 petrol Nissan Terrano with enough T&T till the end of April.
                          Sorry for the Hijack Mick.
                            Harwich is about 55 miles from me....
                              I know, I'll be based around Brentwood, but I like to go flying up near Harwich at the weekends.
                              (not real planes)
