Hello Rob. Spotted a pic of your truck in an old post in the mods section. From what I could see, it had what looked like Mk3 Astra roof rails. If so, did you fit them? Do they have seperate baseplates to attatch the rail to? Did you use "Rivnuts"?, or bolts from the inside?......Any info would be much appreciated. Pics, especially....Cheers....Mick.
@ Wishbone.
Hi Mick,
The rails are from a frontera (swb I think). They have big threaded studs fitted so I just drilled the 4 holes per side and used some 3mm steel plate on the inside as big washers.
I've still got a plywood drilling guide I laser cut at work if you end up getting the same rails.
Cheers,
Rob.
Will sort some pics out at the weekend as the missus has the truck tonight.Last edited by wishbone; 17 March 2011, 19:18.
Peugeot 405 estate rails fitted to mine all those years ago!
http://www.hiluxsurf.co.uk/attachmen...9&d=1131926529
p.s. Thats the wrong date on the photo, as it would have been dark at that time. It was june 2004 if I remember correctly.
[QUOTE=BUSHWHACKER;706814]Peugeot 405 estate rails fitted to mine all those years ago!
Thanks Vince. I know that 406 rails are the popular choice, and there are some really good write ups on here, on fitting them, and call me weird, but I've set my heart on Astra ones....Cheers....Mick." Time wounds all heels ".
