Just emptied the washing machine and phone popped out with all the clean clothes!
Bugger.
Whip the battery out, phone and battery into gruesome hot press, nip to chemist and get yourself a bottle of isopropyl alcohol,
Dismantle said phone,
Wipe down pcbs with said alcohol,
Leave in hotpress for about 3 days,
Re assemble phone and you should be working again....
I have had to soak pcbs in alcohol for.24hrs or so before but it works....
Originally posted by BigBobE View PostWhip the battery out, phone and battery into gruesome hot press, nip to chemist and get yourself a bottle of isopropyl alcohol,
I have had to soak pcbs in alcohol for.24hrs or so before but it works....Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
get a cardboard box put about 5 cm of dry rice in it
lay the phone on the rice with its battery off pop open the case if you can
then cover it with more rice and put it somewere warm
2 days jobs a good en
you may need a new battery tho altho some servive the washer
the rice adsorbs the water out the phone
simple scienceam not die lex sick its you that cant read mate
Originally posted by madcampbell View PostI did the same but took the phone apart and left it to dry out for 3 days. Put it back together. And it worked! .....apart from the fact it stopped making any noise or vibration when it rang!
I now have a waterproof phone which does the job wellam not die lex sick its you that cant read mate
