This thermostat is actually doing my head in. changing the chanel makes no difference to it's operation, it still plays up.
What its doing is when it receives the signal to turn the boiler on the relay in side makes noise and the green light illuminates to say its on but the boiler doesn't do anything. The easy to fix it is to turn the stat down so it sends the off signal, reboot the receiver unit then turn the stat up so it tries to come on again and then it works.
The same happens when you want it to go off, the receiver has difficulty turning the boiler off and instead the boiler will just keep providing water to the radiators.
I'm about to pull this thing off the wall and see if anything inside can be cleaned etc..
Any suggestions? Apart from replace it. Thanks!
