Right then looking for a drop plate so i can hook up a tin snail without dragging its arsenal along the ground.....
Also want it to be removable so don't go ploughing fields when out in the rough stuff.....
Looked at reciever hitches and thought mmmmmm i could mod mine then buy
the insert with lower ball position....
Then had a brain fart what if i brought one of these and mounted it back to front....
So bolt the 6 hole plate to my existing towbar and use the larger plate to adjust height and then be able to remove it by pulling out pins....
What do you think......
