Originally posted by Albannach
View Post
Drilling holes in walls
Originally posted by BUSHWHACKER View PostDepends how often it'll get used really.
I bought a cheap £40 one from Argos about eight years ago and it's still going strong. Don't use it that much, only for drilling with core drills and into stone.Originally posted by Wolfracer View PostMakita.
If you notice, they come in "weights" any 5kg model will blast its way through most surfaces, and you can also get ones that have a jack hammer (static chisel) setting. I got mine for about £50 from B&Q (own brand)and is holding up quite nicely. I got it mainly to bore 110mm holes for soil and vents. It has a mechanical clutch to stop you breaking your arms off when it grabs. This is very important!
But you get what you pay for. Depends how much you want to spend to drill a couple of holes!Do you know that, with a 50 character limit, it's
Originally posted by noobysurfer View PostAre you drilling into brick or sandstone?? Sandstone is also quite tricky to get a fixing in, if it is sugary! Brick should be ok unless it's damp or your on the mortar line.Do you know that, with a 50 character limit, it's
Originally posted by noobysurfer View PostI would suggest a sand, lime and cement mix of about 4:1:1 with a cement dye if it's visible, there a few different colours on the market. I have buff and red if you need it. But without seeing the extent of the gap I can only guess that would be your best,maybe not the easiest solution!
I think buff sounds right. Is red the typical Glasgow sandstone colour?Do you know that, with a 50 character limit, it's
Hi ya mate, i always buy Milwaukee tools, they are expensive, my 18 volt drill was over 300 quid, but saying that, i have had it 10 years, and only replaced 1 battery,and it gets used more or less every day, far better quality than Dewalt or Makita, try brushing P37 tile adhesive over the area you are drilling, about a couple of hours before.www.furryfriendsinneed.com
Hi Albannach
I have a cracking Hilti SDS. Picked it up second hand a few years ago after using them regularly when I worked as a pipe fitter. Company I worked for swore by them....
I'm in Dunfermline but if you've got a job on & want a loan, let me know.
D.
different types of brick
mine old red brick a compleat feker to drill
i used hss bits and a hds drill
it just burns the bits out
mind you my house id made from the old rotherham brickhard as fek
I'd also agree that Makita or Milwakee are the things to buy (my Atlas Copco, which was what Milwakee were called about 12 years ago, is still going strong and I have a Makita drill that was 2nd hand to me about 20 years ago that's fantastic.) The bosch sds battery drills are worth a look too. I'd avoid Dewalt, according to my local supplier they're just Black & Decker with a posh casing and more of these go back faulty than any other make.
Thing is though, if you're only using them now and again why pay £300+ for a quallity drill? B&Q or Black & Decker will suffice.
Can I apply for the position of sad drill anorak? I think I have about 9湯
