Hi Chaps, I have read a couple of other threads but can't seem to find and answer. The issue I have is that my steering has been getting stiff and a tad noisy, just got to work and into the cark park and it was a pain to park. I will check fluids and drive belt in the morning and hopefully it is going to be one of them. If not I guess it will be pump off and a refurb kit. Any other ideas received gratefully....Thanks in advance.
Another power steering issue.
try troubleshooting thead in 2.4 2.8 sectionOriginally posted by Webbo View PostHi Chaps, I have read a couple of other threads but can't seem to find and answer. The issue I have is that my steering has been getting stiff and a tad noisy, just got to work and into the cark park and it was a pain to park. I will check fluids and drive belt in the morning and hopefully it is going to be one of them. If not I guess it will be pump off and a refurb kit. Any other ideas received gratefully....Thanks in advance.
point 80http://www.hiluxsurf.co.uk/showthread.php?t=55797
On this vein, I have a slight leak of fluid from my power steering pump, so I bought some of that 'power steering stop leak' stuff and lobbed it in.
It hasn't totally cured it, but it has slowed it down quite a bit.Sent from the iPad you "lost"
Wossat face for, LOL, its probably only short of fluid, or even better a loose belt!
Forget about the bad things till you've checked the easy stuff.
THEN you can come on here and moan about it!
