Megane Scenic coil problems
  • Megane Scenic coil problems
    Just a heads up for anyone who has a Renault with coil packs (or any other petrol with them I guess..)....
    The wifes X reg Scenic 16v 1.6 petrol started to run lumpy yesterday, then the engine warning light illuminated. This was after a valet including power wash (not in the engine bay I add), so may be due to water ingress.
    Anyway, after an in depth squiz at http://www.renaultforums.co.uk/ I suspected either TDC sensor needed cleaning (had it changed last year) or a coil pack had gone (had a couple done last year too). They are nearly as helpful as you lot..... nearly.
    I removed coils in turn and found that when i removed #2 the engine didnt get any worse, indicating that cylinder was the issue....
    So, Bromsgrove Motor Factors in Worcester did me an aftermarket coil for £30 (yes, ebay = £50 for FOUR, but it was needed NOW NOW NOW) and it took 5 mins to swap out - and it seemed OK.
    Wife drove it a few hours later and came home with awarning light back on and lumpy engine.
    I took it out just now, did low rev stuff, drove it like i stole it etc.. never missed a beat! Wonder if it just needed a clean out of the pot?
    oh and a coil pack, ive found out, is the modern way to get the power for a spark plug - they dont have one coil and a distributor these days, its one coil per plug, or one driving 2 plugs..
    just thought it might help someone!
    If you're gonna be a bear... be a Grizzly.
    Yea, maybe these guys
    私のホバークラフト は鰻が一杯です。
      um..... yup.
        Is the coil pack an aftermarket mod, or is it standard kit?
        私のホバークラフト は鰻が一杯です。
          its standard old chap - sits on top of the spark plug (in this case) in a rubber tube.
          Tis all new to me. Last time I looked at a pertol engine it was in fact to change a cracked distributor cap. You remember those days? didnt need a laptop to mend a bl00dy car, just a socket set and a haynes manual.
          those were the days.....
