Hat off to Autoglym Super Gloss Polish!
  • Hat off to Autoglym Super Gloss Polish!
    decided to see if I could get rid of the Shropshire Laughter Lines the surf developed back in October.... and just thought I'd show off my new lights!
    Before:
    After
    Still got side 2 to do yet!
    www.johnthebuilder.info
    Nothing like a good t-cut & polish session!
    Well done mate, she looks stunning now, but ya need to get some wire-wool and wd40 on them back quarter bumpers..
    Wire wool wont scratch em either, just spray WD on and rub off the rust, comes straight off, clean it up with a cloth, then spray bit more WD over exposed areas
    www.vidamusic.co.uk
      Random question - did you buy that truck off a Polish eBayer in Burton-on-Trent a couple of years ago?!
        looks good mate
        have you seen that miget with no legs take pictures of ya truck
        or is it a ghost
          Er, no, but what do ya know?
          I might be able to add some info if you're right...
            Not even T-cut, just polish!
            The only use wire wool would be on the rear quarters would be as reinfircement for filler. They're all the way through, and the rust is just well, there instead of a hole, if you see what I mean.
            Better get in the queue for some more....
              aah! i need to buy some too, and when i do, i'm gonna seal the back of them, then seal them, them seal on top of that, then put a layer of seal on, then seal it.............
              www.vidamusic.co.uk
                What about the fronts! Isn't it the chroming "thickness" thats the issue?
                I'd be happy with plastic equivs. Does anyone do them?
                Also on a different note, "Wonder wheels" alloy wheel cleaner (strong acid) brings up the white lettering a treat.
                  So does Vim. Or Cim or whatever the feck it's called now!
                    You cleaned your tyres with strong acid?
                      Oh yes, forgot about that, used to use it on my white trainers. Vim as it was had a bleach in it. Good $hit that stuff!
                        vim
                        i seem it used when i was a kid
                        i did not even know it was still around
                        any rubber that been on will need treating with an rubber protector
                        i never buy any autoglim its called rubber treatment or tango
                        i use vasalin
                        its the best stuff for rubber
                        thats why its on jonnys its not for lube its for self life
                        its the best thing on the rubbers that needs to be cleaned
                        vim is very tame bleach it will rott rubber very slowly
                          Don't know about you Judwak, but MY rubbers don't last that long!
                            my mask has lasted years
                              Originally posted by JUDWAK View Post
                              vim
                              i use vasalin
                              Vim is only used to get the lettering white, it's then hosed off.
