Hi Dave, thanks for the PM, this is the cylinder i already have, body lenght if about 17", width about 60mm, stroke is about 280mm, it's a fairly big one and a pity i dont have two, do you think it'd be man enough to raise the step with the missis on? i know a lot depends on the air pressure, if it helps the compressor is from an ambulance air suspension system as is the tank (i also have an old larger tank from a junked small comp i can adapt, perhaps i could use your smaller rams to push the step and this to lift, mayby via some sort of "pivot" method as you suggest, what do ya think,
i got this ram from a member on here that i think lived in or near Hastings, cant for the life of me remember who or i'd contact them a see if they had another ram,
cheers Dave
cheers Dave
