water flow?
  • water flow?
    and not in the car
    its in my house i have running water down stairs but not up?
    the hous is red hot its been warm most the night
    i did awake early hours because its was soo cold and i poped the heating on
    then since getting up around 8 thins morning there has been no water on the upper floors the header tank is running low too
    any ideas on how to concker this?
    found it luckly its not burst i managed to pump hot water down the cold water pipes left that in and repeated it after 30 mins
    foundthe said frozen pipe hair dryer and its sorted
      You're pretty quick mate, you should be a plumber! Took less than 15 minutes, and I bet you had a cup of tea as well!
      Oh Nana, what's my name?
        i did but i have been at it since i got up
        its like an oven in here
        but i dare not let any heat out
          Originally posted by JUDWAK View Post
          and not in the car
          erm....isn't that the law of gravity...water disnae run upstairs
            Nah if its lucky enough the water has a stairlift!!!!!
              Yes but you also need to overcharge yourself..
              __________________
              Back in the day Baby
