If you feel bad about the environmental damage then go off to a farmers field and kill a random animal - It would be your very own 'carbon offset'
air con
well lets just say that if you get caught degassing ur air con by someone who's in the know then u are likely to face charges, on the otherhand if there is no gas in there (you should be able to see via a sight glass on the a/c compressor) then your ok to take the pipes off without any problems..need more power! ;-)
dont air con run on ammonia gas?
deadly stuff dont beath it in
i dont use it for heath reasons google old air con it will show you why
it was first used in cars in 1939
the ealyest account of air con use was in rome ran by cold water running around the walls of posh houses and not run by ammonia gasesam not die lex sick its you that cant read mate
