My rear section exhaust failed last night just in front of the bean tin size silencer - I take it this is a common problem from what Ive seen on here? Replacement from Roughtrax on route.
Whilst removing the bit that was hanging off had a butchers underneath at the rest of the underside and could see lots of surface rust on the chassis, suspension, drivetrain and metalwork (not body) was wondering if this is normal on a Gen2 or is something to worry about? .... or am I just being fussy
I realise its not the weather for it now so the plan for the spring is to wire brush off the loose rust and hammerite the metal to stop it rusting anymore and then underseal it? unless you guys can suggest another / better way or different materials to do this with.
Ill try and put a pic up later for comparison with your own.
