Originally posted by michael1703
View Post
rough in morning
moisture in the fuel by the sound of it
The natural properties of diesel fuel make moisture related problems more critical in diesel equipment. Diesel fuel is heavier than gasoline, therefore the volatility (ability to vaporize) of diesel fuel is much lower than gasoline This lower volatility allows air and moisture to infiltrate the diesel fuel in both vehicle and bulk storage tanks much faster than gasoline. Water condensation in diesel fuel storage tanks is a routine problem that must be solved by all users of diesel fuels. The longer the fuel is stored, the larger the problems become. and breathe....... I found a good way of getting rid of moisture in the tank is to let my dear wife put 40 litres of petrol in the tank yes the primary fuel should be diesel.
Oh what fun I had draining the petrol out of the tank in the sub zero FUN FUN FUN.
like has been mentioned before its a diesel yes they run a bit ruff in the cold but unless it is really causing you concern just live with it, you could of course change filling station you use this wont cost you any extra will not require any service items. just a suggestionEat.Sleep.Surf.Repeat.
mines like this too, after the fuel filter change and then i took it for a real good run on the motorway and pushed the old girl a little (outside lane speeds for as much as i could) she's been a lot better - still lumpy
my other car is a modern diesel and thats lumpy and noisy for a minute or 2 as well
as said above - diesels can eb liek this - from reading lots of other similar posts and searching about I have found that when starting from cold, to not climb in the truck, turn the key ignore the 'glow plug' light but listen for the clunk of the relay shutting off (its easier to hear from outside) then turn the key - has fired up first tiem every time since doing this - then i push the little advance button for a minute and she warms up lovely - then set off..
since I've been doing that the start up proceedure every morning has been much better...
might help??
Originally posted by shokenore View PostThe natural properties of diesel fuel make moisture related problems more critical in diesel equipment. Diesel fuel is heavier than gasoline, therefore the volatility (ability to vaporize) of diesel fuel is much lower than gasoline This lower volatility allows air and moisture to infiltrate the diesel fuel in both vehicle and bulk storage tanks much faster than gasoline. Water condensation in diesel fuel storage tanks is a routine problem that must be solved by all users of diesel fuels. The longer the fuel is stored, the larger the problems become. and breathe....... I found a good way of getting rid of moisture in the tank is to let my dear wife put 40 litres of petrol in the tank yes the primary fuel should be diesel.
Originally posted by lawsy View Postmines like this too, after the fuel filter change and then i took it for a real good run on the motorway and pushed the old girl a little (outside lane speeds for as much as i could) she's been a lot better - still lumpy
might help??
