Question for the IT guru's (laptop buggard)
    Bleedin messin about with laptops, and im struggling up here..tchh.
    Struggling so much you've got time to #### about with your Iphone
      I'll have you know, im sat ata desk...just replaced a whole(bl00dy heavy)hub assembly and im taking a little break...mind you i'll be done by about 9.
      Every time ours palys up al, i switch the router off for a minute...always works for us.
      Non intercooled nothing.
        try this one
          The router is fine mate (it has a display on it ) and there are 3 people currently using it around the house to get on the net!
            Originally posted by BigBobE View Post
            Again thats just an exe file, not the whole program, if i transfer that to the lappy it will then need to go on t'net to get the full d/l and install!
            Cheers Bob
              My daughters lappy wont connect to the internet!!!
              I have tried 3 different ways,
              1, O2 payg dongle
              2, Usb wireless dongle on my networlk
              3, ethernet cable straight to the router (a Bekin N1)
              All types say they are connected, but internet explorer wont display any pages and tells me i'm 'offline'
              Checked that the box is not ticked for "work offline"
              So what the hell should i look at next.
              (all 3 other wireless devices in the house are getting on net just fine!!)
              Yours
              Baffled of Sussex.
              Hmmm Vista...
              Log on as Administrator
              Start:
              Control Panel:
              System/Device Manager:
              Network Adapters.
              Right click on each one and select uninstall.
              You will get the usual warning...go yes.
              When you have uninstalled them all go:
              Action
              Scan for hardware changes.
              It should then reinstall the devices and drivers and reset the default settings for the adapters.
              Try that first.
                Assuming you tried what I put earlier follow the instructions in this link to reset the TCP/IP settings http://www.mydigitallife.info/2007/0...og-corruption/
                  I.E has a virus, tip lemsip down the USB hole.
                  Can't you get firefox on a memory stick from one of your other 'puters?
                  Sent from the iPad you "lost"
                  • #24
                    Just found an old magazine free disc with a copy of firefox on it!
                    Will let you know if it works
                    Alan
                    • #25
                      Did you see any of my posts
                      • #26
                        Did your first, trying the second now,
                        sorry too many things going on to reply instantly!
                        Help is much appreciated
                        Alan
                        • #27
                          Cheers Bob
                          But you say it connected so it should dl. For you....
                          Or check in tools that you haven't ticked work offline.
                          • #28
                            It can't download a file if it cant access the web! (browser not working) so the fact there is a NETWORK connection means nothing!
                            • #29
                              That link you sent seems to have done something!! But IE still is not working
                              Since following those instructions and re-starting, all the auto updates are starting! (they have been sitting on the task bar unable to work!)
                              Alan
                              Just letting windows update do it's thing then i'll try sorting the browser!
                              Alan
                              • #30
                                If you still cant get online, download winsock fix on another computer, save it to a USB stick and run it on the problem machine.
