Originally posted by greeley
View Post
To be honest I haven't tried all the functions. The radio is fine as is the DVD player. USB works well. Rear view camera is also fine but depends on the camera bought. Not yet set up the satnav or TV functions. (To have TV you need to buy a preview box.) Additional DVD screens are also well catered for & work well. Has amp connecting leads etc.
I had to enlarge slightly the area around the slot so it would allow the unit to fit easier. I also had to set the unit 5mm further out from the dash so as not to impede the sliding screen. The sliding screen cannot be set at too much of an angle or the gear change hits it when selecting park.
Other than that it all appears to be pretty good. menu takes a bit of getting used to because of all the things it can do.
All I can say is that it's not a bad bit of kit for me.
As to the clinometer: I have replaced the standard x2 dash bulbs with blue leds. Standard lights are very poor like most of the other lights in a surf.
Hope my info helps.
Regards
