Which winch?
  • #16
    Originally posted by Nick V View Post
    Thanks for the feedback chaps. Not wanting to appear a tight arse, (no, I'm not Scottish ) I can't justify spending much more than these cost for a winch that will probably will be used very little. However, having said that when I do want to use it I want it to do what it says on the tin!
    Cheers, Nick
    Not being thick {no I am not english}
    Both those winches are cheap tat, and will let you down.
    Brian
    • #17
      Originally posted by sledge View Post
      nick try this guy he's top rated and fairly local to at times he gives money off if u pay in cash and collect it yourself. got mine from him. oh and he supplys everything you need inclucling staps rope you name it as far as winches goes he will have it.
      Hi Neil, which guy?
      Cheers, Nick
      "The force will be with you, always!"
      • #18
        Meeeow Fair point about the winch being cheap, but that's what I wanted feedback for,
        Cheers, Nick
        • #19
          Hi Neil, which guy?
          Cheers, Nick
          sorry for got the link
          http://stores.ebay.co.uk/WINCH-IT-RECOVERY-PRODUCTS
          he's only in ferndown.
          • #20
            Thanks Neil, that helps!! Will pop down and see him,
            Cheers, Nick
            • #21
              Originally posted by davec170 View Post
              I don't want to express an opinion either way. However, I bought a 1300lb superwinch off the first guys. Top quality, quick delivery. I also changed my order to include 15mm plasma rope and cables to mount the solenoids remotely. They made my order up same day, hand wound the rope, asked what vehicle it was for and how I intended mounting it. They were attentive and helpfull. I didn't feel they were just after a sale. Can't comment on the other guys, as I've not dealt. Good feed back too though.
              Wow you ain't gonna recover a surf from much with THAT!
              1300lb....
              Nissan Patrol for on-road, and a Land-Rover 110 shed for off-road :-)
              • #22
                1300lb....
                Fair call! I should have typed 13,000lb. Last time I used it in anger (last month) was to remove a row of tree stumps that the back hoe on a JCB failed on. I did double the pull via a snatch block though. Stumps made a nice popping sound as the 4-6" roots parted. Surf sat on "idle-up", tied to an Amazon. Winch never laboured - didn't even slow down noticeably from no load speed. I would like a Warn/insert named brand here, but this works fine and is well provided for with spares (same parts as Warn/insert named brand here)!
                I'll loo after it. Time will tell whether it'll reciprocate ()
