Rear window not working
  • Rear window not working
    going to start investigating the rear window...
    any advice or links to threads that may be useful..
    at the moment, if i press the button - nothing
    if i put the key in th eboot i can here it clicking as it tries, but no movement..
    noticed wiper hadnt docked so moved it by hand, then window moved about 1/4" and stopped..
    any ideas where to start? also is there a manual override??
    any help would be appreciated
    thanks
    steve
    i did a thread on it but it seems to have been removed
      i tried searching and found topics - then just get file 404 not found...
        me too
        even on posts with the link in them
        i still get the same sh1t
          well i say
          to it
            pop the boot open
            see the catchs on the side that let the back door know its locked
            pop them in with a screw drivet
            this lets you send the window up and down with out it being closed
            be carfull because it can just fall out if you send it up too much best off being a 2 man job
            like this
            pop off ya door card before hand
            its held on with these
            and take off the rapping witch ripps easy try not to rip it
            then there is a metal backing plate take that off too
            the insides look like this
            grease all the runners cogs and vasaline all the rubbers on the window
            if its your motor thats gone its
            do the same has this is were the motor for the back window is
            your motor looks like this
            and dont forget if you need to take the door handle off
            take the bolts out
            remove the pin arms on both your door lock and handle
            make sure you know what way they came off because they are not the same
            any how i have loads of pics
            give me a shout if there anything else you may need to know before ya take it apart
            other people on here know a lot more than i can ever tell you
            ohh yea its better if you play a bit of this while doing it
            http://www.youtube.com/watch?v=eKtfjsonPFE
              thanks
              steve
              Common problems are: motor worn out/gear broken and the channels at the bottom of the window rust. RoughTrax do a replacement
              If it wont go down, I think its a case of climb into the boot take off the panels and make it go down manually by removing the motor and pushing it down to get the tailgate open and investigate
                A motor from an mr2 fits, you just need to turn it 180 degrees and is a hell of a lot cheaper.
                  Only if you buy an O/S one. N/S fits in correctly, but the plugs may be different.
                  Most similar year Toyota motors will fit.
                    my opinion-from experience - for what it's worth - get a motor that fits in the correct orientation - ie motor above gear.
                    if you get a different handed motor and mount it 180' out - yes it will fit and work but condensation can and will gather in the motor and with the motor below the gear - will not be able to drain or escape - causing corosion in the motor windings etc and lead to premature failure.
                    It happened to me a while back.
                    Incidently you could swap it for one of the rear doors motors if you don't use them often??
                    Plenty of motors on ebay some even recond' or service exchange for £60 ish - new one from dealers will be a small fortune.
                    Everyone thinks I'm paranoid!!
                      window wont go down, so cant pop boot open
                      if its just clicking could it be electrical rather than the motor??
                        If you hold the rear wiper up, does it work then?
                          http://www.youtube.com/watch?v=ZO2qO9FaIWU
                          helped me
                            [QUOTE=lawsy;669340]window wont go down, so cant pop boot open
                            QUOTE]
                            you can gain access to mech with boot closed. just climb in the back via rear seats.
                              [QUOTE=jaky cakes;669388]
                              QUOTE]
                              so you can pop the covers off with the boot closed, cool - i'll try that then..
                              just not easy clambering through when your my size
                              tried re-setting wiper - it doesnt lift and snap up, so lifted it and held up - still nothing
                              i can hear something clicking as tho power is getting through - where are teh relays located??
