I am in the proccess of giving the interior of Lucifer a makeover.
What i want to know is that i won't be using the 4wd on it(its not connected anyway) so would it be ok the just cut the hi/lo selector just above the gearbox so i can fit the rubber gator properly to cut out some of the noise and cold air blowing up through.
Also it should be ok to take the front diff out completely and the front drive shafts have them cut off just before the hub so that the bearings etc are still sealed
Lucifer won't be used out in the icy/snowy weather as i am using it to hire out so i need to keep it in tip top condition.
