Originally posted by shokenore
View Post
Strange tyre pressure readings
i doff my hat to you sir all these bloomin years and i have been thinking that N was used in hi performance car tyres and N2 was not considered pure enough to be put inside lovely low aspect pirellis and the like
i have used OFN in a few of my m/c tyres did it make a noticable difference ? i doubt it and to be honest it would be way "cooler" to use ignited lighter fluid to inflate your tyres
Eat.Sleep.Surf.Repeat.
OK, bearing mind that 99.9% of people use regular air, what cold pressures are recommended for road use with 265/70x16 Bridgestone Dueller HTs?
If people venture off road on standard wheels and tyres, what is the safe limit to lower them to? (Not thet the HTs are any good off road)
Thanks,
Mark
Depends on tyre for side wall strength, wheel width to prevent tyre breaking its seal, etc etc. I would trial it on your driveway. Keep letting air out until tyre looks bulging at bottom, but by no means flat. Remember too little and middle of tyre can raise up, then you're just running on outsides"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
The recommended pressure is 28psi, but most of us run at 32 or 33.Originally posted by markp2 View PostOK, bearing mind that 99.9% of people use regular air, what cold pressures are recommended for road use with 265/70x16 Bridgestone Dueller HTs?
Any lower than 15-18psi and you'll run the risk of the tyre rolling off the beads. If you have bead locks (which you don't) 8-10psi is OK.Originally posted by markp2 View PostIf people venture off road on standard wheels and tyres, what is the safe limit to lower them to?Do you know that, with a 50 character limit, it's
Yes, sorry, not very specific, or technical or scientific or anything really.Originally posted by Albannach View PostI'm sorry, but that is bad advice.
In my own head, I had a picture of a tyre thats only just spreading at the bottom, to increase contact patch, and not to enable the tyre to "mould" around rocks etc, which is probably more what the OP was after as a response. I wouldn't drop more than 10 psi in any case, as when you have finished playing in the mud you need to get home!
My experiences come mainly from quarter miling, but I suppose extreme heating and centrepetal forces are factored in to keeping the tyre "round".
However when I was a lad my Jago Geep on 31x10.50's woiuld happily drive on 12 psi, but 2 people could pick it up...."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
i put in air to what i like it to be
and check em every week
if i let the tyre down for grip
i do it with a gage i made my self to what i like it to be
but my tyres are muds not road tyres so it says what to do on the side wall
tiz not hard
