Idler
  • Idler
    I've got to do my timing belt soon and have bought the belt and tensioner - do I need to do the idler at the same time? do the bearings go? my engine is a bit rattley and squeaky - I'm going to change the power steering and alternator belts at same time.
    It's prudent to change the idler and water pump when you do the timing belt on a 2.4. I have a nearly new idler if you want it, £22 delivered.
      As you have an LN130 same as me, then get
      http://www.roughtrax4x4.com/?doc=16&cid=605&vid=1399
      And from what I've read , also because of the bits that have to be removed to do the belt on a LN130, you should also change:
      Water pump
      and coolant, as the job really requires the rad to be taken off.
      peace
      cal
      www.thecellardwellers.co.uk
        Water pump
        peace
        cal
        That's the kit I bought - will do as Albannach suggests and change water pump and idler at same time - along with coolant and thermostat
          I'll take it, will have to wait a few days though, I used my card in the builders merchants and they managed to charge me twice! Waiting for a refund!
            No worries, PM me when you're ready.
