I'll get it sorted, it just means I'll have to use a chippy that I dont know and that's always worrying! I just can't afford these worktops to be done badly they're too expensive!
Kitchen worktops
He's actually in sw19 working...I bet he'd be glad to drive the enormous distance to you.Originally posted by puddlesurfer View PostI didn't mean for you to make a trip down especially Si, I meant if you're down London way for some reason could you do it!
I think TinTin is a bit far away too!
Non intercooled nothing.
another little tip that might be handy, solid or strip wood worktops can expand and contract quite a bit across the width, so its usual to leave a gap on the wall side to allow for expansion this is usually covered by tiles if thick enough or a matching upstand, i have had to replace solid timber worktops where no gap has been left, they have been fixed onto the units at the front which in turn were fixed to the wall, consiquently the worktops had bowed upward in the centre and on one of the corners the joint had ripped up the centre biscuit. These worktops had been correctly finished with the proper oil but moisture still caused them to expand.Originally posted by si tate View PostI biscuit all types of tops regardless but with solid tops your male & female cuts are only a very slight trim on each joint so that you are virtually just butting them together.
Some good points mate & another one is to have the worktops in the house laid flat & unpacked a few days before you fit them so as they are at room temperature.Originally posted by soramad View Postanother little tip that might be handy, solid or strip wood worktops can expand and contract quite a bit across the width, so its usual to leave a gap on the wall side to allow for expansion this is usually covered by tiles if thick enough or a matching upstand, i have had to replace solid timber worktops where no gap has been left, they have been fixed onto the units at the front which in turn were fixed to the wall, consiquently the worktops had bowed upward in the centre and on one of the corners the joint had ripped up the centre biscuit. These worktops had been correctly finished with the proper oil but moisture still caused them to expand.If its not broke don't fix it.
I'd love to be able to say "be over tomorrow to do them", but sadly the earliest i could do them would be early october!!
I've just been let down so i'm shorthanded on my job! It HAS to be finished when the client returns from america on the 3rd! (guess who's working 12 hour days!)
Sorry dude
Alanwww.amcbs.webeden.co.uk www.xjrestorations.co.uk
Quote TinTin
Sorry dude
No worries Alan, I've got a friend of a friend coming over to have a look tomorrow - I'll just have to pay whatever it costs - as long as it's not silly money.“Do or do not... there is no try.”
I'm almost tempted to go out and buy the bits I need and do it myself - with plenty of practice on the old work surfaces first! but I'd rather pay an expert
