wanting replacement lift but can find any
  • wanting replacement lift but can find any
    hi all,
    im looking to replace my 3'' rear lift and 2'' front lift. i know i can use landcruser springs but the place i got the old ones from has gone bust. also i was going to get some procomps but cant find any or sites like roughtrax dont sell them any more, any ideas where and what kit to put on. shes runnung ranchos at the moment but cant find them either.
    cheers all
    also anyone selling ball joint drop spacers?
    All been discussed to death last week. Have a quick search.
      cheers man.
      i have been trying to search but the search engine on this hates me, dont supose you have a link to it.
      cheers
        I'm on a phone right now so cant supply link. Search for threads started by puddlesurfer
        As for lc springs, I got mine from milner off road (use Google search). About 55 quid for the two.
        Oh Nana, what's my name?
          Finally got to a PC:
          http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=65238
          The springs I bought for my Surf:
          "SUSPENSION COIL SPRING REAR (PAIR) - 003784"
          Although I cant find them on the site anymore. They were £55 plus postage and VAT.
            A bit more searching and I found your posts back from 2008
            http://www.hiluxsurf.co.uk/forums/sh...4&postcount=32
            http://www.hiluxsurf.co.uk/forums/sh...t=50596&page=4
            So the HDJ80 ones with part number 003784. If you get the Surfenstein cups as well then they sit propperly in the mounts. Without the adapter cups the top of the spring is too big and will move about. I have the adapter cups and they sit just like normal springs do.
              Statements like this should be followed by "in my opinion" as there will be many on here who would disagree totally with that statement, you are giving new members an unbalanced veiw.
              Brian
                Mine have been fitted for six years now and haven't dislodged. (Standard 'Cruiser springs though, you still get the lift but your spine will last longer!)
                  My 2.4 had LC springs without spacers, no issues at all.
                    The locators are a nicer engineering solution. Without them, they just kind of 'almost' sit on the rubber locators properly, but not quite. No-one can deny that. LC springs are larger in diameter.
                    It will work OK without them, but its 'better' with them. Just depends if you want to stump up over £100 for something that just makes the job 'proper' rather than half-assed
                    Will, as I know you've got no money, go for 'half-assed'. It works fine.
                      Yep, my 3.0 has the spacers and they are the better/correct (but not essential) solution. It does look neater too.
                        I thought it ended up sitting an inch and a half lower on one side ?
                          lol, but, na no more half assed, i now have money, yay im even looking at a total bushing overhaul.
                            Yep, the 3.0 sits lower on one side too. What's your point?
                              My point is that you have a definite issue there..... unless you think that a truck sitting 40mm lower on one side than the other is a 'non issue'. Did you use the same set of springs on the 3.0 ?
