I knew someone who used to rally one, a UK RWD Corolla though. Most in the UK now are the jap import version, whatever they're called - Kumquat or something.
Not necessarily, exhaust manifold runner length and diameter of the exhaust affect throttle response too. Remember BDA and LCB manifolds of the seventies/eighties? (Thats old skool tuning, you're much too young)
Car exhaust is a science, especially with V engines.
You're not wrong! But a lot of different things can effect the outcomes, like cam timing, valve lift and duration and port sizes....
I did play around with the cam timing though. I advanced it to give more bottom end power, as being FWD, the twin 40 trumpets only sat an inch or so away from the bulk head - so you could say I had a problem with induction. I then retarded the timing a little off what it was set to to see how it drove.
Bad thing was, it was engine out, head off job to adjust it.
Could you not have fitted a vernier cam pulley?
Bit risky adjusting cams by 'feel' valves banging on pistons is not good.
Ported and polished a few heads back in the early eighties on friend's Minis. I can still remember the blisters from all that valve grinding.
I did have a vernier. Problem was, it was an OHV engine, and the cam cover wasnt easily accessible!
I actually converted the standard single chain to a double chain setup used on the Escorts. What a pain that was since no one designed it for the FWD crossflow type at the time. I never had any slap. Kent cams said that no less than 100 thou should be machined from the piston crown valve pockety type things. I had only 60 thou machined and never had any slap. Even up to over 7k rpm. I did have guidance from a senior engine builder though.
When compared to the Burton Power engines with the same spec, the engines he had built were making up to 30hp more (mine included).
I only adjusted the cam timing by a few degrees each way. May be four degrees.
