Hi all, a very good morning to you. Q: Is it ok to use heat tape to patch up a hole in the exhaust? and if so how long will I get away with this for?
Heat Tape.
Ah right. I don't think that will seal it, that's just a wrap. Exhaust bandage (from Halfords or the likes) is your best bet. How long depends on the severity of the leak and the quality of the repair, anything from a few seconds to a few weeks.Do you know that, with a 50 character limit, it's
Depending on which part is holey.. I have most of the exhaust system for a 3litre second gen I just replaced that you are welcome to for £40 collected. The tail pipe is rusted through (and snapped off hence the replacement) and one of the pipes has seen better days.
If you want to post your email address I'll send you pics from my phone. I'm in Surrey so depnding where you are in Berks it could be doable. I'm away from Fri so would have to be tomorrow evening if you're interested.
Originally posted by kiwiholic View PostThanks, I'll give that a try instead. If i do a decent job it should hold me out until payday!!!
If it's a silencer, use gun gum around the hole, coke can opened up to support the repair (coated as above), and bandage to hold it all together.
If it's where a pipe goes into a silencer, I've never successfully repaired one of those leaks!Do you know that, with a 50 character limit, it's
