Of course not!! It's utter, utter bullshit, and the reason fools and money are easily seperated.
If you look at a jet engine, it has some large fans in front of the air intake, called turbines, that spin to compress the incoming air, using just the velocity of the incoming air to turn the blades
Nope, combustion causes the compressor to turn, not airflow!
to enable air to be compressed into the jet engine before combustion takes place.
What spins the turbine then? Magic??
If you compress the air into the engine you get more power output from the same amount of fuel due to the increased explosive force created.
Its not compressing the air, its merely an obstruction spun by the air thats being sucked in by... yes, the combustion process
This is why a jet engine is far more efficient than am internal combustion engine found on all modern vehicles.
No it isn't.
Cant fault his ad though. F1 engineers, aerospace, both mentioned! Top man!
He forgot to mention it makes you more popular with women, increases the size of your penis, and makes you rich - it has been recommended by a world war 2 Spitfire pilot, and is used by a famous motorbike display team!
he forgot to mention the performance boost you get sucking in air from a hot engine bay instead of the cold stuff that the engine wastes energy heating up....
