T-Belt warning light
  • T-Belt warning light
    Hi All,
    My timing belt light came on today
    I know how to reset it
    But should I change it? On the Tbelt cover there is a sticker (badly faded) that say's next belt due at 150,000km my car hit 140000km today (when light came on) so I shouldn't need to change it until next year.
    If I do change it - like I know your all going to advise me to, shall I take the head off and look? Then replace this lot as well:
    If I do it'll cost me £250 (Roughtrax)
    Head Gasket 1989 - onwards £36.00
    Diesel head gasket set for fitting 2.4 cylinder head £31.99
    Head bolts £22.00
    Genuine Thermostat £16.75 (might as well while it's open)
    2.4 & 2.8cc Engine Cam Belt Kit £59.99
    Water Pump 2L/3L 2.4/2.8 Diesel Water Pump (might as well while it's open)
    Then I'd better pray that the head itself is ok because my money situation is tighter than a camels ar$e in a sandstorm - should I? or should I leave it a month or two when if I need a head I can afford one.
    Who's got a good 2.4 head for sale?
    Why are you intending to remove the head?
    Non intercooled nothing.
      I forgot to say, I do get a bit of smoke on start up and lose speed up hills, It's probably not to do with the head just wanting to go too fast!
        So...it's a 2.4 ( I had one, it smoked on start up). It lost power up hills as well. Unless your losing coolant, or your temperature is an issue, leave the head alone. Don't take it off just to look!
        The t-belt change is all that's needed.
          ...and the tensioner.
            water pump while it's all out and accessable?
              Nope. Timing belt light is on, everything else is fine...leave it alone.
                lol - not a bad plan - I am going to do a coolant change and major flush through anyway, thought it might be best to change the thermostat and water pump - I dont even know where the water pump is, I know something squeaks I'm hoping it's just a belt (I know the power steering slips a bit) I've already got the belts to change 'cos I bought them when I serviced it but never got around to them.
                  Stop wanting to faf about with it, its fine, do the belt & tensioner & leave it alone.
                  Actually have you thought about turning it into an amphibious surfs.
                    Actually making an amphibious car is kind of a dream for me!,
                    I was thinking MK1 Surf with no roof, doors welded shut etc would be cool, I really like these:
                    http://www.gibbstech.com/
                    but the daddy of all amphibious vehiles is this:
                    http://www.terrawind.com/terrawind.htm
                      There's one of those amphibious buses does a route near Glasgow, including a Clyde crossing that used to be done on a ferry. They reckon it was cheaper to get the floating bus than keep the ferry going!
                      Andy
                      http://www.surfingafrica.net
                        If I'd known that I may well have checked it out while I was up there for the last week or so.
                        Still, I'm sure I'll visit again at some point (probably next summer now).
