Hi all,
Techie question, I am thinking of removing my Aircon and just using the pump to do the excellent air compressor mod that GAMEDAWN did back in 2004. Here:
http://www.hiluxsurf.co.uk/forums/sh...ard+compressor
I understand roughly how it works.
I need a pressure switch and release valve - easy to get from ebay, as is pipe, and a airline oiler (Maybe a regulator for when I want less pressure such as blowing up Inflatables or using the air blower)
I'm going to use an old fire extinguisher bottle as the reciever tank (undermounted) they are rated to serious PSI so should be no problem.
>>>So can the pressure switch go anywhere on the pressurised side of the system or does it have to go on the tank? Can it sit next to the compressor?
>>>Oiler goes on the intake side?
>>>The 12v goes into the pressure switch then out to the a/c compressor?
>>> How do you make the compressor run without gas? I read on this forum that the A/C compressor wont lock in without gas in.
What am I forgetting? Any idea's would be gratefully recieved
What else can I remove?
The A/C rad, condensor (but where is he condensor located?)
any other bits to be removed?
