It's oozing
  • It's oozing
    Is this bad???
    you come over all unneccessary Ian..
      don't get any turps near it, I washed down some panels today at work and the turps made that foam turn back into a nice gooey mess.......or maybe that's the look your aiming for.
      Alan
        I've gotta ask though......why the foam?
        And where did you get the arches?
        Alan
          try acetone on it, it works on wet foam...not sure if it will clean off set foam though.
          Regards
          TFB
            http://stores.ebay.co.uk/tigertrucks4x4
            The foam is to give them a bit more ......1 i'm bound to smack one off roading so it to help hold them together ...... 2 due to not being for that truck i need to build them out a bit ......3 you should have seen the rust and metal i have had to cut out the rear arches and it also helps to build up before filling
              nooooooooooooooooooooooooooooo ooooooooooooooooooooooooooooo, you t#t,i meant take the arches off first and fill them with expanding foam.then cut them back.jezzzzzzz give a boy a mans job.......
              whatever you do dont try and clean it off.let it harden then cut it off with a sharp knife.
              www.overfab.uk
                [QUOTE=BioHazard;653445]http://stores.ebay.co.uk/tigertrucks4x4
                Just added them to my ebay favourites (for when I put 33's on my truck, lottery win, or loads of overtime, whichever happens first)
                  Originally posted by BioHazard View Post
                  Is this bad???
                  you like your surf alot to do that all over it
                    No you didn't .............
                    We talked about drilling holes
                    See what happens when i work un-supervised
                      lol,i know(i just didnt think you would make quite that much mess.),it will be fine,remind me never to let you ice a cake.
                      www.overfab.uk
                        Anyone any idea if any of the other arches in that eBay store will fit a 2nd gen Surf?
                        I've heard a few recommendations about Tiger Trucks in various places...
                          !!!!!!! Thought Id walked in on the set of a porno movie!....Cheers....Mick.
                          " Time wounds all heels ".
                            Forget Debbie does Dallas - BioHazard does Mechaphilia (technical term, I did have to look it up)
                              Reminds me of the guy who had "relations" with a princess....
                              ..... burnt his c*ck on the exhaust pipe....
                              www.johnthebuilder.info
