hello all,
i have a problem, and all advice would be appreciated,
may i drink from you fountains of knowlage,
what ive got,
2.4 auto , ssrx,
what ive done recently,
oil/air/fuel filter change.
checked all rubber hoses/ replaced some wich look a bit worn, made shure all rubber hoses (including the turbo relay one) are connected correctly.
run red-ex thru her, and sprayed turbo cleaner up the air inlet pipe (supposedly cleans all air pipes/turbo)
disconnected battries & ecu fuse to clear all codes/ problems
my problem,s,
it all started a few years ago, i noticed on motorways i had a lack of power goin up hill,s but only some times, it seemd as if the turbo would cut out if i slowed down (traffic) but would not re-engage when i sped back up (no whistle and no green light!) but this would only happen some times,
now fast forward a few years, the same thing has started happening on normal roads.
driving along get to 2000 revs, turbo whistles, green light comes on feel the power surge, and some times the turo carries on doin what its meant to do, and some times it cuts out and i feel the loss of power, truck then crawls along at the speed it got up to, and if im goin up a hill the it slowly loses speed,?? its only an intermittent,if i can take my foot off accelarator, let the revs die down, the turbo seems to kick back in? (main problem)
now ive tried to run a diagnostic on her to try and locate problem area (got me paper clip all ready) but!!! having never noticed it before when i put the key in, the engine warning light/picture does not light up?
one dashboard dismantling episode later, and found out no light bulb in socket, so popped the suspension hard/soft light bulb in the engine warning light socket,and!!!!! nothing
still no light
still no joy
still no diagnostics
still no power
i have noticed that in the fuse/rely box there is a hole where the fuel heater relay should be ? would this make any diffrence to engine warning light?
seems the problem has built up so maybe scud on a sensor?? maybe mass air flow?? (where is it) but before i go any further i would like to hear any advice from you guys,
sorry for waffling on, but i think ive coverd it all now,
thank you
what ive got,
2.4 auto , ssrx,
my problem,s,
still no light
still no joy
still no power
thank you
