Yotatech forum racist warning (banned)
  • This was THE best thread for ages. No red buttons, iffy brakes or the like.
    Just plain old discussion,abuse,pi$$ taking and a complete deviation off topic...
    Well done everyone.
    Non intercooled nothing.
    • Originally posted by gwh200 View Post
      Well done everyone.
      I was thinking the same thing. Just like old times
      Oh Nana, what's my name?
      • Originally posted by dieselboy View Post
        Tig is very easy. You only add a rod when you actually need to add metal to the weld. I would start off very low say 60 - 80 amps. It will take some time before the metal is liquid depending on what you are welding and the quality of the metal. Just make sure you use a suitable mask, gloves, bench and a long sleeved t-shirt unless you want sunburn. Arc eye isn't much fun either!
        What gas will you be using? We used Argon but I think (dont quote me) that you can use carbon dioxide to stop contamination.
        Tungsten Inert Gas, run pure argon gas.
        If the metal takes a while to melt your not doing it correctly.
        A mig auto mask is not dark enough for tig unless it is switchable.
        If you can weld with oxy ace then you should manage tig.
        I spent 7yr as a tig production welder, it may be easy at 14 gauge and below., go weld some 20 gauge or even car panels with out distorting them.
        Brian
        • Originally posted by yoshie View Post
          I was just giving some tips to judwak. I was saying it may take a while to turn liquid on such a low setting - ie for practice. If you;re jointing two pieces together you want the hottest setting possible without ruining the pieces to try and prevent heat soak and distortion like you mention. I used an auto mask with different light settings. Was much easier than a solid non electrical mask. And we only used argon but I have heard of people using CO2 as a cheap alternative? Never tried it myself though.
          btw I never took any courses or qualifications in welding.
          • cheers dude
            has for the gas its mi dads so it will have what ever gas it should have
            everything has to be spot on for mi dad to have it
            he wont have time to show me how 2 use it
            i will take the pionts in
            thanks dude
              So was I mate, wasn't a dig or an attempt at arguing. Just my opinion.
              Brian
                Cool beans!
                http://www.youtube.com/watch?v=tjr3P27WnjM
