Fuel priming help needed
have you checked over the entire engine and made sure all the electrical connections are connected properly?
if you have an air line try shoving it in the fuel tank and pressurising the tank to force the fuel up the lines,crack off the bleed scew on the pump.
has it got an immobiliser on the ignition???? make sure this is working ok.
if all else fails put your ecu into someone else truck and see if it still starts,if it does then its not the ecu.then theres always a can of start you barsteward.
also check all the fuses including the glow plug fuse.www.overfab.uk
It just bugs me, but I 'will' fix it!!!
I tried an airline down to pump on inlet fuel pipe and switched ignition on, should I have gotten fuel at the cracked injector pipe end?Alan
no you wont get fuel to the injector like that,i think all it does is circulate the fuel return system.Originally posted by KERRSURF View PostIt just bugs me, but I 'will' fix it!!!
I tried an airline down to pump on inlet fuel pipe and switched ignition on, should I have gotten fuel at the cracked injector pipe end?Last edited by surfenstein; 17 July 2010, 18:50.www.overfab.uk
if i remember rightly the rotary pump has an ecentric plate,that rotates and pushes small plunger type pistons in and out (a bit like a pressure washer pump), these then feed fuel under pressure to the metering head,tony knows more about these pumps than i do.im pretty sure you cant get fuel to the injectors without the pump turning.Originally posted by KERRSURF View PostDoes the pump have to be turning then to get the fuel up to injectors, I thought it might be open but going by your reply I suppose not.Last edited by surfenstein; 17 July 2010, 18:58.www.overfab.uk
i cant for the life of me understand why engine manufacturers need to use these systems,yes they had to make engines more fuel efficient but electronics are soooooooo unreliable.
