Brake line clips
  • Brake line clips
    I had someone replace my brake lines with braided ones (for the lift) and one of the clips that hold the brake line to the chassis broke. So now the line goes through the mounting bracket, but there is no clip to stop it floating around. The drivers side is fine.
    Does anyone know where, or have any clips - can I buy one from you?
    Thanks!
    Oh Nana, what's my name?
    Milners have them. They're about 50p
      or ask stormforce
        Thanks both!
        I'll see if Rich responds
          90468-08034 is what I believe you need, if it's the clip between the flexible and metal brake line.
          Nev
            Bottom of this page.
            http://www.milneroffroad.com/categor...p?cID=9534&p=2
            Nev
              Thanks everyone that replied.
              Nev, whilst you're here, I think I have a little problem with my ECT power button since doing a body lift. Either it's stuck on or it doesnt work at all. I don't have a working dash bulb for it (never have since ownership).
              Do you know if I can short the plug under the centre column to turn it on, or do you have any suggestions?
              JUDWAK has pointed me to the connections going to the gearbox.
                Replace the lamp!
                  Replace the lamp!
                  Its a mission to take the dash apart! Was going to do it when I get round to stereo
                    30 minutes is hardly a mission! And you don't take any bits off to do the stereo that come off to do the dash.
                      Well then I have been mis informed? Do you have a how to on how to change said bulb?
                        Nope, sorry. But all that has to come out is the top (black bit) of the dash, 5 screws I think; and the 4 screws holding the dash in.
                        Just thought, I lied! The heater control cover has to come off to do both jobs. Sorry about that.
                          Sorry mate, no idea about that one.
                          Nev
                            Thanks for replying!
