Hi Guys,
I am new here and was just recently fortunate enough to pick up a 3rd gen Surf in great condition. However I have had some battery / electrical problems.
I have been reading a lot of threads on this forum so far and it seems there are a few people with similar problems. Surf01 had an issue where his truck wouldn't start, but as soon as he jumped it he had no issues until he left it over night again.
I basically have the same issue, the truck turns over just about but not enough to get the engine chugging. However as soon as I hook it up to a car or a battery pack it fires up with out to much hassle. It has the winter pack dual batteries, just about everything on this vehicle is electrical.
I tried to work out what was draining my batteries, I have ammerter'ed all the fuses I can find. I also put the ammeter inline with the battery to see what kind of parasitic draw was happening with the engine off. It was only 0.240amps. At that low draw it would take a huuuuuggggeeeee amount of time to drain 2 x 70amp batteries.
I metered the batteries with the engine running to see if the alternator was topping up properly. My understanding is that there should be around 13.9v whith the engine turning and the alternator charging the battery. However I had more like 12 - 12.4v with the alternator charging.
Anyway, sorry that was such a huge essay but thought I would give you the background story. Right now I am charging the batteries one at a time with a proper black and decker charger 20amps (not cheap). I will be putting both batteries back in once they are at full charge, meter with the alternator again and I am hoping for higher voltage.
However If I don't get the voltage, does any one have any suggestions? Check the fan belt? Replace the alternator...?
Appreciate your time.
Cheers,
Rob
Cheers,
Rob
