T-BELT light
  • T-BELT light
    The T-BELT light has come on at 100K. I had the belts changed at 93k so I assume its some primitive electronics which has kicked in. Before I pootle down to my local backstreet garage can someone tell me what to tell the grease monkey to do as I am sure the sharp sucking of teeth and 'Never worked on one of these before' will be a precursor to a £100 bill for a 10p job.
    As a by the by I had to have the cam sensor on my Merc changed last month. Because the AA had done the diagnostics the monkey very kindly ONLY charged me the fitting. 10 minute job, £60 bill. Thievin' toerag.
    Yours,
    Jaundiced of West Yorkshire.
    klicken bis das blut kommt
    In the centre of the dash there is a small rubber bung, pull that out and push somthing thru to reset the light. Have a look at the thread suggestions below this post as well for more info.
    Mike G
      Remove the rubber bung on the clear plastic cover on the instrument cluster and poke something through to press the re-set button. Toothpick works or long match stick.
        Blimey, I've been outfingered!!
        Now we've just saved you about 40 quid, you can by a blue star.
          have you got oil on your fingers Vince causing them to slip of the keys....
          Did Jo and Craig enjoy the weekend away
            I assume being a 95 its a gen 2, if so there is a little rubber grommet in the dash over the speedo, remove that and insert something long n thin through the hole and push the reset button. Then go to PO and post a 60 quid cheque to me as I'm skint. H
              Yeah, they came home early sunday morning and woke me up!
                Yours,
                I'd have only charged you £50 mate.
                  You need to be quicker on the replies H cause this lot don't mess about..
                    You see,
                    wonderful things these Surfs
                    As a technologist I was expecting ECUs and techy mumbo-jumbo, £100 bill and a 2 day wait. Instead it's just a rubber bung and something long and thin.
                    The week just got better.
                      N theres me thinking you lot were all at work when I found an unanswered post. H
                        Blimey 'Fast Fingers First' out-fingered ???? get a grip man !
                        Death rides a Black Horse
                          i did my bit today by getting the last orders out for this week as i am away from Weds for an assessment for my LGV2 and ADR and then did a motorbike recovery and now i got to sort tea out for the mrs and boys
                            You see,
                            What I love about them too, it's technology that actually makes perfect sense.
                            If they didn't have a function they would be art, never understood that either art has a function doesn't it?
                            Anyway I digress.
                            peace
                            cal
                            www.thecellardwellers.co.uk
                              If they didn't have a function they would be art, never understood that either, art has a function doesn't it?
                              Anyway I digress.
                              peace
                              cal
                              Oh yeah!
