Fuel Pump seals...
  • Fuel Pump seals...
    When I was using a 50/50 veg diesel mix my fuel pump started leaking BIG time... I switched back over to straight diesel & this has all but cured the problem... I've just got the pump seals kit in from Milners so that I can sort the pump seals & go back 2 using a bit of veg again!! After doing my homework I've read that two seals can be done with the pump in-situ by taking the top cover off & that this cures quite a few leaks... Just wondered what u guys on the forum think- should I take the time out to remove the pump & do all the seals in one go or is it worth trying just the two top seals first?? I'm inclined to take time out & just get the pump out & sort the seals in one go, but for the sake of time & hassle I think it might be worth changing the two top seals first & seeing how that works when I start using veg again.... Just wondering about the experiences of other guys on this forum & how successful they've been at stopping fuel pump leaks by just taking the top cover off & doing the top pump seals?? Opinions folks?...
    whenever i do anything like this, i always do the whole lot, unless you know for sure that its just the top seals.
    at least you neednt worry about any of the seals then.
    My Surf eats knuckles for breakfast!
