Mechanic in Leeds (W.Yorks)?
  • Mechanic in Leeds (W.Yorks)?
    Can anyone please recommend a decent mechanic in Leeds, pref. one who knows Surfs?
    VALENTINO ROSSI 2009 MOTO GP WORLD CHAMPION
    Hi Splash,
    Where in Leeds are you, and what do you want doing?
    Most jobs arn't that hard to do on a DIY basis. 2.4 or 3.0
    Gman.
      Hi Gman. Thanks for the response. We live in Kirkstall. She's over - heating when we go up any hills! We're hopeless at DIY, so wouldn't know where to start with changing the thermostat or anything, it took us a month to work out how to fix the speedo We use the same garage every time but he said she didn't over heat when he took her out (on the flat, along the ring road) so he didn't know what was wrong with her. We'd just like someone who has a clue, to have a look, so we don't kill her with ignorance.
        p.s. She's a 3.0L diesel turbo.
          Hi Splash,
          Try these things first, and see how you get on.
          Is the expansion bottle over flowing? it only needs to
          be about half full to start. make sure the rad is full.
          Check the auto trans fluid is at the correct level, do this
          with a hot engine, on the level, h/brake on, go thru all
          the gears a few times and check the level, (engine running in N)
          it's marked hot/cold if low, top up.
          Replace the radiator cap and thermostat and "burp" the cooling
          system to remove any the air in it, (heaters on).
          Hope this helps.
          Gman.
            Thanks Gman, I'm sure we can manage that without actually killing her,we'll give it a try & let you know how we get on
              Hi fattysplash, if you do need a machanic you can try "graham" at autoworld on stanningley road "07970542918".
              I bought my surf from him & he knows them inside out & TBH i would'nt trust anyone else with my surf.
              Good luck.
                Fit a seperate transmission cooler, they're around 30 quid plus a couple of hours of your time.
                Going up long hills causes both the transmission fluid and engine oil to become overheated and the trans cooler in the bottom of the rad can't cope so all that extra heat causes the coolant temp to rise and spew out.
                As said check and/or replace the transmission fluid using the two bucket method. Just draining from the sump bolt is pointless really.
