Quick question for the LC converted. 2nd Gen
  • Quick question for the LC converted. 2nd Gen
    Could someone tell me their rear rim to wheel arch measurement and what size wheels they have. I have LC springs and mine measures about 15-15.5'' and I thought standard was 13-13.5'' on a second gen i.e 2 inch lift from the springs?
    Thanks guys!
    what shocks have you got fitted.If they are standard then they may be topping out preventing the full lift
      I have plus 2 shocks fitted and are not fully extended....any other causes? I have arb drop link extensions and panhard drop bracket from Bushwhacker.
      I also don't find the back end particularly stiff as some people complain of, but that could be the shocks.
        Thanks guys!
        Not sure what you're asking.
        Are you saying you got a 2" lift when you put LC springs on?
        If so, thats correct , 2"
        私のホバークラフト は鰻が一杯です。
          i had 3" lift on mine with the lc springs fitted
            I'm just interested as to how much lift the LC springs have given people as I would have thought it should be a standard amount but I have +2 where as others get +3 or +4??
            I had +1'' with lift springs before, If i had added 2" coil spacers then I would have got more lift than with the LC springs which bugs me a bit!
              Oh I see, said the blind man..
              I think its generally excepted that LC springs produce a 2" lift, although some, as Richard has mentioned do get 3".
              Yours appear not to be included in that "some"
              sorry
              私のホバークラフト は鰻が一杯です。
