injector pump
Hi ,the fuel line to the tank is clear i blew down that when it first conked out,Is the fuel primer the unit which is fitted to the bulkhead passenger side which the fuel filter is connected to and has the black button or plunger which you press down till its hard,if it is,in my last post i described that i isolated the primer by putting the feed pipe for the injector pump directly into a gallon container of diesel,,,, so in fact the container was acting as the fuel tank,,
so i just stared into the engine bay,then i saw it,a broken wire the one that comes from the unit on the top of the pump just by where the injector pipes go,it must have been just on the verge of breaking totally when the surf stopped running,so i wasnt getting a proper signal,any way an expensive fix..thanks to all who tried to help
