My surf 3.0 TD 1KZ boiled after rad went late last year and the cylinder head cracked, we had a replacement recon head from Kuruma heads fitted. 6 months of no problems but now water has started chuffing out the overflow of the expansion bottle again even though weve not overheated at all, everthing was changed for new during strip down last year. Has anyone experienced problems with re-con heads ? or could we have a different problem ?
cylinder head
Further to the post, we have had the head tested and its fine and also the head gasket looked ok, can't see anything wrong with the block, help has anyone got any ideas ?Originally posted by hillyheap View PostMy surf 3.0 TD 1KZ boiled after rad went late last year and the cylinder head cracked, we had a replacement recon head from Kuruma heads fitted. 6 months of no problems but now water has started chuffing out the overflow of the expansion bottle again even though weve not overheated at all, everthing was changed for new during strip down last year. Has anyone experienced problems with re-con heads ? or could we have a different problem ?
