they aren't absolutely neccessary but it will help to seat the tops of the springs properly.You will need to speak to surfenstein for these as i think he may still have some made up
You have/had the blue Milner 20% uprated hdj80 springs in yours correct?? I have ordered a pair this evening. How difficult were they to fit, can I get them in without spring compressors if I drop the axle?
I had the l/c springs fitted.Stein and Boyo fitted mune for me as i wasn't able to do it myself at the time but you should be able to do it ok by dropping the axle
I have the top mounts ordered from Surfenstein. If you do a search he posted their number to order them. Cant remember the exact price but theyre around £150.. May be cheaper if someone wants to correct me.
So am I expecting the end of the coil to hang off the top mount a little or something??
Yes, the coil is bigger at the top. To keep the coil away from the damper, the rear part of the coil should sit in the seat and the front part just off the seat on the chassis.
