Upon doing the coolant flush today, I removed the stat so I could flush clean water through the system a few times.
Bad thing was, when I removed the stat I lost the rubber gasket bit.. When I eventually found it (I gave up, put it all back together, burped it and drove home) it was sitting on top of some suspension component - the ring was only half a ring on one side. Looks like it has been eaten by caterpillars.
So since all of the motor factors are closed around here, and I'm not sure if rip off Halfords sell them, what are the differences between the Roughtrax stats?
http://www.roughtrax4x4.com/?doc=11&cid=164
Worst case, I will leave the truck parked up until next saturday and put a new stat in with new ring
