Hi guys,
When I am taking bends at speed or sharp turns a low speeds I hear a grinding noise similar to when your brake pads wear out. It is not the bump stop noise as I know what that sounds like. I read on here people talking of steering stops causing grinding noises but I assume this is another term for bump stops correct??
I also hear the noise under heavy braking and strangely for a few seconds after the brake pedal has been released. I thought it was just pad wear at first but the fact that it happens in corners under no braking makes me wonder???
Any ideas??
Thanks for your help!
Any ideas??
